View Full Version : katun toner
light copies in canon digital copiers when using katun toner, any help?
don\"t use it
had the same problems in Konica also. cutting corners will come back and bite you.
I have used Katun toner over the years on older equipment without any major issues but I stoped buying HP cartridges from the about a year ago, the quality SUCKED!
Tonerbomb
04-08-2005, 03:34 AM
[b] :evil: This usually happens after someone in the hierarchy decides that using aftermarket (better than OEM, HA! HA!) toner is the way to PARIDISE! It isn\'t just K toner, esspecially if it\'s color toner.DON\'T CUT THE CORNER ON QUALITY OUTPUT, HV b/w does ok with some of those other toners. Good luck! :evil: :evil: :evil:
