View Full Version : Miscellaneous C550 with weird prints...
Michko
10-05-2011, 03:56 PM
Hey.
So I have a machine that gives my client weird prints after a while.
I suspect MFP board and maybe memory ?
Never tried to scan.
12135
Albonline
10-05-2011, 04:14 PM
seen this before. turned out to be hv arc flipping out mfp board. check your contacts/grounds on the first and second transfer units.
habik
10-05-2011, 09:33 PM
..nice Albonline...will keep that in mind..I had similar issue when printing B/W and it went away after a while, initially though its BK IU, when changed it improved, however not completely, still little ghosting left ..
Will check again when with client to see if it improves :)
Michko
10-06-2011, 07:28 AM
How can a IU do this?
It's impossible for IU to flip the image, as you can see the yellow to the right did.
habik
10-06-2011, 09:33 AM
You right I did not look all the way on your pdf to the right ....I missed that 90' turn :(
There was/is however problem with Bk IU's and which has been cleared with new batch. Due to bad contact at the back, I had arcing there and it wss causing shifted image a.e ghosting...
Ianizer
10-07-2011, 04:33 AM
Hope I'm not jacking the thread, but I've been searching for some references on gradually pronounced mainscan color shift (up to several mms), culminating in P-21 nearfault codes. O/C front door clears code & puts color aright.
Replaced LPH, PRCB and cleaned IDC sensors... Several hundred copies later, just dandy, life is grand... 'bout to bail and up pops P-21 again. @*&%$^... Oh for the love a Terry Karahura!
-I
