View Full Version : Error Code strange problem Bh163
blago_vd
10-06-2011, 02:37 PM
Hello everybody,
A client bring me in the workshop Bh163 with C0F32. There was not much developer in the developing section. I replaced drum, cleaning blade and developer. After running ATDC adjustment the machine displayed C0F33. So, after resetting the code the machine displayed C0F32 again. I replaced the ATDC sensor, but it was the same situation. The connections between the sensor and the PWB-A are OK.
rex777mix
10-06-2011, 09:16 PM
Hello, you must change the old developer by a new one.
blago_vd
10-07-2011, 07:20 AM
Already changed
jbosman
10-07-2011, 08:32 AM
Hello everybody,
Remove the IU-assembly make sure that you leveled out the developer, run ATDC gain again, if that doesn't work check your toner supply.
