View Full Version : Dead Machine konica minolta c352
tbkarthic
10-06-2011, 03:02 PM
hai i have one problem in konica minolta c352 that machine power light and start key red light only indicated on that panel. then no moment on that machine. i am checked power supply board. any one have idea for this? thank u.
RRodgers
10-06-2011, 05:37 PM
You may have to flash it. Or you could have a bad main board.
habik
10-06-2011, 09:45 PM
Try new memory modules. I had that recently on 2 c253 machines.
acusso1234
10-08-2011, 09:15 AM
Happened to me the same thing on a C352. In the end it was the fault of the hard disk.
If your client does not use the scanner can also leave the machine without. (Disconnecting and disabling it)
tbkarthic
10-08-2011, 02:31 PM
ya i am already checked well. but not changes. have same.
Cacharra40
11-08-2011, 09:43 AM
Try to change the SIF Boad (Board with "L" shape).
EarthKmTech
11-08-2011, 10:04 PM
I recently had an issue with a c352 where when turned on the control panel lcd backlight would not illuminate and the KM logo was all that ever came up on the LCD (barely visible) and nothing else happened.
it was the PWB-M board blown and replacement solved the problem instantly.
Ianizer
11-09-2011, 07:28 AM
Give an NVM recover a shot before throwing money at it.
-I
