View Full Version : CQ uneven density in 6500
levino
10-11-2011, 03:27 PM
Hi
my km 6500 magenta and cyan color varies from side to side ie from left to right margin(parallel to drum)Replaced drum developer transfer belt transfer rollers upper and lower and charger too.Like uneven density correction in 6501 any thing available in 6500?
pls help
kalindd
10-11-2011, 09:58 PM
You can use shims to distance the corona from drum. Google this pn A03UP46200
Albonline
10-11-2011, 10:05 PM
tape works as well.
RRodgers
10-11-2011, 10:34 PM
Corona wires are known not to be installed correctly at the factory on that model. Double check the wire.
levino
10-12-2011, 02:23 PM
Hi Rodgers,
the corona wires are checked and confirmed already,because i already met with that.
Albonline,
Can you please explain how I can use the tapes.
Albonline
10-12-2011, 02:27 PM
Put tape over pads on cro blocks. to adjust distance between charge grid and drum.
RRodgers
10-13-2011, 02:15 AM
Hi Rodgers,
Albonline,
Ahhh so you've seen when they come brand new not set up correctly? Yeah, it's a pain. I've learn to always check them now on all the one's I get.
Sorry I wasn't the one that suggested the tape but I can see how that should work.
GL
levino
10-13-2011, 11:40 AM
Thanx Alboline,
Ill check and come back!!!
