Error code for Konoica 7033
  • vonhetcchtel
    • 42
    [Error Code] Error code for Konoica 7033
    Goodday guys, I have another issue with Konica 7033 and I need your help. It is displaying error code F 35-4. Thanks
  • bushy
    • 34
    Re: Error code for Konoica 7033
    You will need to reset the heat code.
    Go to 25 mode select software switch
    Go to adderess 3-1 to 3-6 and make sure there is a zero in all addresses
    Bushy
    • CompyTech
      Super Tech
      • Feb 2011
      • 706
      It's a fuser code. I would replace the thermistor (fixing sensor) PN: 26NA 8801 3
      Then go in 25 mode software switch 3 - 1 set to 0 to reset the error. If you just go in and reset it with out replacement of sensor, it could cause problems or work flawlessly. Its your choice.
      • mrwho
        Major Asshole!
        • 4299
        Yes, try to reset the error before replacing anything - 9 out of 10 times* the machine works fine just by resetting it.
        * Tested in independent laboratories in Rafakistan. Your milleage may vary.
        Mascan42
        Ibid
