View Full Version : 6000 Duplex Misfeeds
AVux07
10-05-2007, 01:02 PM
I have a 6000 that tries to feed from the duplex tray but stops at the metal exit roller. I know there's a one way gear/clutch in the duplex drive train but the parts list only lists gears or pulleys. Does anyone know this clutch's P/N or can maybe point it out in the diagram? Otherwise, it's alot of work digging it out and leaving them down .
Claudio
10-05-2007, 06:36 PM
The 4 parts I used to replace when the duplex would randomly jam are :
Shaft PN: 1075-2672-01,
Shaft PN: 1075-2597-01,
Gear 27T (1-way) 1075-2671-01,
Gear 35T (1-way) 1075-2595-01.
I could never figure out how to take appart the specific area to replace these parts so I would just bend the frame out of the way to replace these parts because they were very difficult to get to and it will save you a lot of time. Then bend the frame back. Worked for me.
Good luck. Maybe you'll find an easier way.
Claudio
AVux07
10-05-2007, 08:39 PM
Thanks Claudio, that's just the info I need. Bending the frame should be in the disassembly handbook!
