View Full Version : Copystar 1505
bncontrol
10-08-2007, 03:38 PM
Copier has a C-610 error code, do U know what that may be?:confused:
JDE75
10-08-2007, 06:33 PM
I can't find our manual for this unit but I do have for the CS1510 which they are very similar and it states that this code is a fixing unit error. Check all connectors to main pwb if all good then replace fixing unit.
Absurd
10-09-2007, 12:36 AM
Before you replace anything you may want to reset fuser error code with sim # 163 Resetting the fixing problem data
enter simulation mode:Press the stop/clear key, start key
and the left copy exposure adjustment
key in the order presented and hold
them down. Press the stop/clear key.
Enter the number of the maintenance
item to be executed using the copy
exposure adjustment keys or the zoom
+/- keys. Press the start key.
U163 Description
Resets the detection of a service call code indicating a problem in the fixing section.
Purpose
To prevent accidents due to an abnormally high fixing temperature.
Method
1. Press the start key. “CLE” appears.
2. Press the start key. The fixing problem data is initialized.
Completion
Press the stop/clear key. The indication for selecting a maintenance item No. appears
leave sim mode:Enter 001 using the copy exposure
+/- keys, and press the start key.
