bjinnovator
10-26-2011, 07:26 AM
We are a supplier of copier parts, the below are our products for use in Konica Minolta Di450/550/650.
Please contact us: www.bjinnovator.com (http://www.bjinnovator.com)
Di 450/470/550
Upper Fuser Roller
4002-5701-01
Di 450/470/550
Lower Sleeved Roller
4002-5702-01
Di 450/470/550
Drum Cleaning Blade
1136-0901-01
Di 450/470/550
OPC Drum
4002-0291-01
Di 450/470/550
Developer MT 502 (600g/bag) compatible
Di 450/470/550
Fuser Cleaning Web
4002-5732-01 1145-5801-01
Di 450/470/550
Cleaning Web Pressure Roller
1075-5751-01
Di 450/470/550
Thermistor
9372-2000-51
Di 450/470/550
Thermofuse - (Thermostat)
9334-1610-11 4028M60100
Di 450/470/550
Upper Picker Finger
4002-5783-03 4002-5783-01
Di 450/470/550
Lower Picker Finger
4002-5790-01, 4028-5785-01, 4002-5785-01
Di 450/470/550
Spacer Roller
Spacer Roller
1134-5104-01
Spacer Roller
1134-5105-01
Di 450/470/550
Upper Roller Gear 56T
Di 450/470/550
Drive Gear 101T W/Bearing
4002-2502-12 4002-2502-01
Di 450/470/550
Drive Gear 40T W/Bearing
4002-2503-02
Di 450/470/550
Drive Gear 51T
4002-2507-03 4002-2507-02
Di 450/470/550
Drive Gear 28T/31T
4002-2509-02 4002-2509-01
Di 450/470/550
Drive Gear 31T
4002-2545-03 4002-2545-02
Di 450/470/550
Upper Fuser Gear 46T
4002-5709-02
Di 450/470/550
Idler Gear 27T
4002-5710-03 4002-5710-02
Di 450/470/550
Drive Pulley Gear -Original
4002-2556-01
Di 450/470/550
Gear 18T/48T in Paper Takeup Section
4425-3206-01
Di 450/470/550
Gear 60T in Paper Takeup Section
4425-3207-01
Di 450/470/550
Gear 16T/40T in Paper Takeup Section
4425-3212-01
Di 450/470/550
Gear 25T/56T
Di 450/470/550
Paper Take-up Gear 34T
Di 450/470/550
Upper Roller Bushing
4002-5704-01
Di 450/470/550
Bushing
4002-5007-01
Di 450/470/550
Bushing - on the Auger in Imaging Unit - Front
1065-5106-01 1144-0168-01
Di 450/470/550
Bearing for Upper Fuser Roller
4002-5705-01
Di 450/470/550
Handle- in Paper Exit Section
4002-3708-01
Di 450/470/550
Right Side Door Latch (Lever)
4002-3335-01 4002-3335-00
Di 450/470/550
Paper Exit Tray/Receiving Copy Tray
1139-0156-02 1139-0156-01 1139-0156-00
Di 450/470/550
Transfer Bolock /Sep Corona Assembly
1136-4001-01 1136-4002-01
Di 450/470/550
LCD Touch Screen
Di 450/470/550
Paper Pickup Tire
4002-3201-01
Di 450/470/550
ADF Separation Tire
Di 450/470/550
Paper/Bypass Feed Tire-Rubber
1052-5224-01, 4002-3216-01
Di 450/470/550
Paper/Bypass Feed Roller-Rubber
Di 450/470/550
Paper/Bypass Feed Tire-PU
Di 450/470/550
Paper/Bypass Feed Roller-PU
Di 450/470/550
Separation Roller
4425-0152-02
Di 450/470/550
Separation Tire-PU
4425-0152-02
Di 450/470/550
HTR LAMP-UP 120V 850W
9352-2910-52
Di 450/470/550
HTR LAMP-UP 220V 850W
9352-2910-62
Di 450/470/550
HTR LAMP-LO 120V 200W
9352-2910-81
Di 450/470/550
HTR LAMP-LO 220V 200W
9352-2910-91
Di 450/470/550
Copier Toner 300g/bottle
MT-502A, 8936-902
Di 450/470/550
Copier Bulk Toner
MT-502A
Di 450/470/550
Upper Fuser Roller
4002-5701-01
Di 450/470/550
4002-5702-01
Di 450/470/550
Drum Cleaning Blade
1136-0901-01
Di 450/470/550
OPC Drum
4002-0291-01
Di 450/470/550
Di 450/470/550
Fuser Cleaning Web
Di 450/470/550
1075-5751-01
Di 450/470/550
Thermistor
9372-2000-51
Di 450/470/550
Di 450/470/550
Upper Picker Finger
Di 450/470/550
Lower Picker Finger
Di 450/470/550
Spacer Roller
Spacer Roller
1134-5104-01
Spacer Roller
1134-5105-01
Di 450/470/550
Di 450/470/550
Di 450/470/550
4002-2503-02
Di 450/470/550
Drive Gear 51T
Di 450/470/550
Drive Gear 28T/31T
Di 450/470/550
Drive Gear 31T
Di 450/470/550
4002-5709-02
Di 450/470/550
Idler Gear 27T
Di 450/470/550
4002-2556-01
Di 450/470/550
4425-3206-01
Di 450/470/550
4425-3207-01
Di 450/470/550
4425-3212-01
Di 450/470/550
Gear 25T/56T
Di 450/470/550
Di 450/470/550
4002-5704-01
Di 450/470/550
Bushing
4002-5007-01
Di 450/470/550
Di 450/470/550
4002-5705-01
Di 450/470/550
4002-3708-01
Di 450/470/550
Di 450/470/550
Di 450/470/550
Di 450/470/550
LCD Touch Screen
Di 450/470/550
Paper Pickup Tire
4002-3201-01
Di 450/470/550
ADF Separation Tire
Di 450/470/550
Di 450/470/550
Di 450/470/550
Di 450/470/550
Di 450/470/550
Separation Roller
4425-0152-02
Di 450/470/550
Separation Tire-PU
4425-0152-02
Di 450/470/550
9352-2910-52
Di 450/470/550
9352-2910-62
Di 450/470/550
9352-2910-81
Di 450/470/550
9352-2910-91
Di 450/470/550
MT-502A, 8936-902
Di 450/470/550
Copier Bulk Toner
MT-502A
