View Full Version : Miscellaneous KM Bizhub c252 HELP!?
charlibravo
11-11-2011, 09:25 AM
:(Hi, I have huge problem and I need some help. I cleaned up (transfer belt, IU-s, etc.) my bizhub c252, but when I go to Print/Copy the entire paper is full covered with blue straps all over. I put the picture in attachement. The second problem is that I cannot do some network adjustement on bizhub c252 because the button is "disepeare"? Please help me, what next I can do to fix this problems?
12857
12858
Thanx in advance
groovy
11-11-2011, 09:50 AM
Your cyan IU has dead, please replace...
charlibravo
11-11-2011, 09:59 AM
Thanx for rapid response, one another thing, how do I fix that the network button appear in Bizhub menu?
Thanx
sometime i face this problem, and within 2 minutes, the network menu will appear back. if it does not appear within the time, normally i will unplug the ethernet cable. sometime it work. it happens when you switch off the machine and you quickly enter the administrator mode. i dont know what cause this, probably the machine is refreshing and still in the process requiring permission from the network.
charlibravo
11-11-2011, 11:38 AM
now I had one problem more:(. Error code C-E002?! How can resolve this?
Thanx
RRodgers
11-11-2011, 11:45 AM
Yep what he said.
RRodgers
11-11-2011, 11:46 AM
Do you have a Fiery attached to it?
charlibravo
11-11-2011, 11:57 AM
sorry, but I dont know
RRodgers
11-11-2011, 12:00 PM
Is there a box bolted to the back of the machine? FYI a tech would know.
charlibravo
11-11-2011, 12:02 PM
no
charlibravo
11-11-2011, 02:28 PM
where I can find Firmware Imaging Toolkit 2006, please help me whit this. I have new firmware but need this tool:(
Thanx for help
remati
11-13-2011, 03:10 PM
Thanx
You must install the last version of the firmware and if the code cames again ,go to the "service mode and do the HD ""version up""
sorry for the late reply, but no, the machine got no fiery attached to it. thank you
