Machine have 65 K copies.
After 1 -3 k full thick black line starts to appear. Couse of thick line is GRID on charge corona. One side looks like its burned (the side where is a thick black line) but I clean it easy whit alcohol. Probably toner buildup on grid. I replaced developer and didnt help ( black line started to apear again for 1-3 K copies) then i replaced charge corona and again same problem in same interval.....
Everything looks normal! Drum looks normal( organic photoconductor layer didnt peel of anywhere!)
I must point that I didnt change drum in 60 K copies only developer and charge corona.
Usualy when I clean charge corona grid its good for another 30 to 50K copies.
HELP!
Thank you in advance!
HELP!
