View Full Version : Bizhub C350 Jam Tray 3 Only
mrfuser
11-18-2011, 01:04 AM
Getting a jam from tray 3 only. Top 2 trays work great. Swapped out feed head assembly, still jams. Code shows Tray 3 and Vertical Transport Jam, again, ONLY from TRAY 3.
Any thoughts?
Kelly
kingarthur
11-18-2011, 05:00 PM
have you checked the mylar strip on the tray itself..had a problem with that being worn before
mrfuser
11-18-2011, 05:17 PM
Swapped.trays, same.result
mo0651
11-18-2011, 05:23 PM
where is the paper at? sensor in feed unit...had a broken one once. Does it get to reg roller?
RRodgers
11-18-2011, 07:00 PM
Replace the one-ways that are right on the feed and sep tires.
mrfuser
07-31-2012, 12:01 AM
Does not activate paper lift. Just shows jam when try to copy or print.Does not show error until you try to copy and.only from try 3. I have swapped.lift motor , board and sensors for back showing drawer in place. Still nothing. No lift.
mrfuser
08-10-2012, 11:47 PM
no help here? Must be someone out there that has done this job.
