View Full Version : Did somebody try this? develop and KM...
inutelkamo
11-22-2011, 10:58 AM
Did any1 here tried to use the printer driver of Bizhub C650 on a Develop Ineo +650??
You think it will work?
Or did somebody here has a MAC OS 10.6 that using a ineo +650?
What version of driver are you guys using?
habik
11-22-2011, 11:57 AM
ALL WORKS
I am using KONICA drivers on DEVELOP Machines every now and then when I can't for some reason access Develop.de site which is sister (code) site to KonicaMinolta.com
Just find what driver you need and it works fine. Btw Konica recently released NEW driver for LION OS X..and it works magic.
Just to add..make sure you have Bonjour switched on on your C650 or +650 (by default it is, but double checking won't hurt)
DEVELOP GmbH - Home - Develop (http://www.develop.de)
KONICA MINOLTA | United Kingdom (http://www.konicaminolta.co.uk)
TheOwl
11-22-2011, 10:06 PM
As the Develops and the Konica Minoltas are the same box, then yes the drivers will work as both machines understand the same PDL's. If you wanted to, you could even use HP PCL drivers, but you would lose functionality.
Just be carefull if you ring support for printing issues though as this setup might not be supported by Develop / Konica Minolta.
inutelkamo
11-23-2011, 09:16 AM
Hey guys..
Thanks for the ideas...
I am excited to try this on my existing +650...
Thnx for the ideas...
