View Full Version : service mode for bizhub C6500
hmidani
11-27-2011, 01:54 PM
Please, how can I enter to the service mode for bizhub C6500
I tried to stop 00 stop 01, but it does not work
hello friend ...salut mon ami marocain tu peux nous donner ton problèmes exacte ....sur cette bizhub c6500?
RICOHMAN
11-27-2011, 08:56 PM
HI PRESS UTILITY KEY PRESS METER DETAILS MAKE SURE YOU CAN SEE METER COUNTS ON SCREEN THEN PRESS STOP ZERO ZERO STOP ZERO ONE THIS SHOULD HELP YOU :cool:
eCopy
01-04-2019, 04:42 PM
Hi,
I'm trying to reset my corona counters and can't get into service mode.
My tech told me go into the counter screen then press stop 00 stop, but I can't get it to take.
Can you help please?
Thanks in advance
Rod
kenpio
01-04-2019, 06:33 PM
Hold the UTILITY key down while you turn the sub power switch on. Hope that helps.
eCopy
01-04-2019, 06:49 PM
Turns out it was stop 00 stop 01
Page 275 out of 1222 in the service manual.
Phil B.
01-04-2019, 08:08 PM
Hi, I'm trying to reset my corona counters and can't get into service mode.
Thanks in advance
Rod
your tech?
are you the end user?
i really feel the 'tech' shouldn't give out that info to an end user, due to the fact if not done properly, or you go into the wrong menu, you can turn the unit to a BRICK... -= IF =- you have a contract including LABOR have HIM come do it.. (since you are already paying forit)
eCopy
01-04-2019, 08:38 PM
your tech?
I am the end user and I don't have a contract. My 'tech' is actually a friend and I try to bother him the least I can.
sadanand
01-08-2019, 12:57 PM
press utility -0-Stop-00-Stop-01
Phil B.
01-08-2019, 06:50 PM
smart .. now you've not only posted for the world to see... you have given a NON TECH the abiity to turn his machine into a pile of nothing if done incorrectly.
eCopy
01-08-2019, 07:06 PM
Hi Phil,
As a NON TECH, have I done something to offend you?
Rod
Phil B.
01-08-2019, 07:16 PM
Hi Phil, As a NON TECH, have I done something to offend you?
Thanks Rod
having been in this industry for 30+ years... having SEEN what a non tech can do on their own to trash a machine..... seeing others techs share info that the maker of said unit FORBIDS sharing of such INFO... I find it had to swallow that a fellow tech would risk their TECH ID for handing out such vital info.
do not know what YOU do for a living.... but how would YOU feel IF I started doing your job?
