dickierock
12-02-2011, 11:36 AM
Hi all,back with another weird one,
Have a df75 booklet finisher with attachment kit ra1 which was originally connected to a utax 1040 (km4035).
Now I needed to switch the finisher to a second 1040 and then I get error code 440 0r 450 which is communication problem with the finisher.
I've seen these errors before when the finisher is not the right type for the machine but here is the problem I am having.
1.They first and the second machines are identical. utax 1040
2.They are both "bam" machines i.e. they have the power button on the op panel.
3. The serial numbers are only three digits apart i.e. ending in "470" and "473"
4. The firmware is identical.
5. I have checked both maintenance reports to find any differences and adjusted accordingly.
6. Both machines have the same ram/memory.
7. The finisher works fine on the first machine but not on the second.
8. I have tried a finisher on a third machine and the machine errors also.
I cannot get this finisher to work only on the original machine,so Im not sure why,maybe something Im not seeing,only have the one of these and if its not working soon im gonna make that zero!:D
If anyone can shed some light Id be grateful.
