Copierdave
10-24-2007, 01:54 AM
This customer has both a new bizhub C352 w/fax and a bizhub 500 with fax. The customer has to dial 9 to get an outside line.
The only way you can fax out is by using on-hook Dialing. Can't fax out using direct faxing or speed dial.
I have the latest firmware installed, the Marketing and Fax target set correct, the machine dialing method set to PB. I have played around with pauses with no success.
PLEASE HELP! NEED INPUT!
