View Full Version : Miscellaneous bizhub 600
NEOTECH
12-05-2011, 09:19 PM
i have a problem in fuser lamp not trun on and not showing any error code i cheack fuser unit other copier machine is working properly.
if someone face like problem plz help me.
thank's
Rajeevk
12-26-2011, 10:25 AM
Do you replaced the fusing or tried to rest any error code?
thank's
toner head
12-27-2011, 04:46 PM
If you suspect fuser because machine is saying "warming up" you are barking up wrong tree.That can be because the handle is not in the vertical position or you are having a toner issue in developer. You can run process control and see if any errors occur. Clean process unit sensors if an error occurs.
