View Full Version : bizhub 350 copy problem
goldencup
12-06-2011, 07:58 AM
Hi, I would like ask if you have encounter this problem on bizhub 350.
I did replace a different developing unit (3 units from a good machine). At first copy operation, the image is good then after maybe 60 copies the image started to get dirty. I think there is something in the machine that is causing this... any idea? Any adjustment that I should do or something that I should check? Thank you very much
goldencup
12-06-2011, 08:08 AM
...by the way when I look at the drum, it looks like there is no problem and still in good condition, also checked, cleaned and change the charging assembly.
Benjamin1976
12-06-2011, 12:55 PM
I would check your contacts for the drum unit, In one of your samples I can see an image of the charge grid. I would try a different drum unit if the drum contacts look good.
Hansoon
12-06-2011, 05:29 PM
I agree, something with the contacts perhaps.
How about the discharge lamps? What bothers me is the pattern however.
Next time you post samples please indicate the feeding direction with an arrow.
Hans
WildbillC
12-06-2011, 06:25 PM
You say you replaced the dev unit. Did you also replace the drum, because it looks like drum ground issue to me.
I think everyone agrees its some kind of contact issue.
fixthecopier
12-06-2011, 10:45 PM
We just had one spraying toner and making poor quality copies. Background was dirty. Found the erase lamp not working.
pepper38_cnd
12-06-2011, 11:07 PM
Since each time you change the dev unit , the copies were good until about 60 copies and then it got worse from there? Is it possible the your customer got the wrong toner into the machine? If you put a dev unit back into the working machine you took it out of does the problem follow? Note swapping dev units on this series usually results in a code unless both machines are relatively new drum and dev.
goldencup
12-07-2011, 02:25 AM
regarding toner issue all are originals, I did clean and even change the grid and charging assembly. Also I've check the contact inside the drum and also replaced the drum. What puzzles me is that if I test the problematic developing:p on the GOOD machine, the problem is still there. By the way I test the good developing unit on the problematic machine:D:D:D and wait for the problem occur. When the copy problem appear, I return the developing unit back on the GOOD machine, now the copy is not good too. I did it on two more good developing unit, same thing happen (I think something in the problematic machine:mad: makes the drum unit like overcharge maybe or whatever???) Anyone have encounter this? What do you think is causing these problem? Thank you
[ATTACH=CONFIG]1328613285
pepper38_cnd
12-07-2011, 04:23 AM
You just answered the question, if you put a good working developer assy in the machine and it is destroyed and no longer works in any machine then you have a toner problem ( it doesn't matter if you have verified that the now installed toner is OEM ) there is definitely the wrong toner in the toner hopper! That is the only thing that would move back to the previously working machine from the non working machine.
goldencup
12-07-2011, 05:31 AM
thanks for the reply. As I continue my observations here, I try to separate the developing unit: The Upper Part (with Drum,Blade,Charging) and The Lower Part (with Developer). I put the Lower Part (the one with copy problem) on the Upper Part of the GOOD unit and test it. the Lower Part is OK! therefore I have no problem with the toner. Same with the other two unit that was also affected. I now test the Upper Part (the one with copy problem) on the Lower Part of the GOOD unit and test it, now the copy problem appear as seen on the previous attached images. Which now I focus my attention on the Upper Part. I test the charging and the drum also one by one and now found out that the problem is the drum (though it has no damage and really in good condition if you look at the drum physically).By the way, these are all performed on a GOOD working machine. Given that the drum is the problem and can easily be replaced, the problem is that if i put it back on the problematic machine:mad: , it might damage the drum again :(. Something in the machine is still damaging the drum. I was hoping some of our friends here might have encountered this and solved this mysterious problem.
Thank you very much for all help and suggestions
Hansoon
12-07-2011, 05:49 AM
Just some thoughts:
The tiny white dots inside the black pattern are very symmetrical. Do they correspondent with the drum separator claws? If yes, than there are two things coming to mind: A) Stray light shining on the drum (not likely cause its too even spreaded from front to rear) or somehow a charge coming from the transfer roller on the drum. The latter could mean a defective HV unit. Did you check those drum discharge lamps by the way? Are they going on AND off?
Hans
Hansoon
12-07-2011, 05:50 AM
Just some thoughts:
Hans
goldencup
12-07-2011, 06:13 AM
Just some thoughts:
Hans
hi sir hans, yes they do correspond with the claw, I was also thinking of some kind of light but I have no idea where it could be coming from. How can I see the discharge lamp going on and off :o I removed the back cover but all I can see is the glow of the heater lamp :D
Hansoon
12-07-2011, 08:31 AM
Are you able to swap the HV unit? (PM Page 9 position 3, behind the image unit)
Hans
pepper38_cnd
12-07-2011, 11:47 AM
Ok I was confused, I thought originally that you were just changing the Developer unit. Now I realize you were swapping the entire Image unit which consists of both the drum assy and the developer assy. You have narrowed the problem down to the drum assy. Can you see physical damage to the drums that have been tried in that machine? Did this problem just occur, or did it start after some sort of servicing?
Since you say the copy starts out good and then deteriorate after about 60 copies. I would not think it is not a contact problem. The light striking the drum, sounds possible but the problem occurs when the machine is running and the drum is turning not after the drum has been sitting still. I guess you could verify if it is actually the drum by taking the DRUM Only ( not the Drum Assy ) out of a non working unit and placing it in a working unit, and testing. If the problem follows then something is destroying the drum.
Is it possible that each drum cleaning section is being compacted with toner ( possibly the recycle tube on the toner hopper is plugged ) ?
goldencup
12-08-2011, 02:11 AM
@Hans: I have not yet swapped the HV but I'm now in the process of testing it. I'll be back for the feed back.
@pepper38_cnd: the drum is physically in good condition and no damage at all. All cleaning section were cleaned.
rpesa
02-10-2013, 10:08 AM
I have the same problem. I changed the cleaning blade and I used the old drum because the new one was not the proper one. I said it doesnt matter to have a new blade with old drum for 2-3 days till the new drum arrives.
Before replacing the blade the copier was printing ok but with tiny dots from normal wear of drum.
Zeldaman
02-10-2013, 10:30 AM
Hi there!
Yes it sounds strange, but about 10 month ago my fellow technician had a similar problem and after some day's he got the solution: the customer had opend the OEM-Tonerbottle & put in some old toner he had in his desk!After changing developer & new toner the problem was gone. You can imaging his cursing about this stupid customer!
Greetings....
rpesa
02-10-2013, 10:36 AM
Hi there!
Greetings....
Yes the toner can be a problem but this copier is the copier that I use in my own copy shop.
EarthKmTech
02-10-2013, 11:49 AM
Genuine bizhub 350 drums come as a unit.
why dont you try a GENUINE NEW drum unit and a GENUINE NEW developing unit with GENUINE developer and see what happens. :cool:
I NEVER have any problems with these machines at all, ever.
rpesa
02-10-2013, 11:58 AM
And of course a new copier.
Why not calling a service tehnician?
First of all this forum I GUESS is NOT for people replacing CRU items like Genuine fusing unit, Genuine Dev unit, Genuine drum ...
And I am Ricoh service engineer with few years of experience.
And I realized where the problem can be, the conductive grease on the drum pin. I remembered what I have done
but if it is a toner problem a c2557 will arise.these machines are famous for c2557
