c5501 with error c-2823
  • primozks
    • Dec 2008
    • 27
    Does anybody know what this could mean?
  • bizhub1
    • Sep 2008
    • 230
    Re: c5501 with error c-2823
    Charging potential correction
    Vh/C aborted.
    Printer control board (PRCB)
    Drum potential sensor board
    /C (DRPSB/C)
    Drum potential sensor /C
    (DRPS/C)
    • primozks
      • Dec 2008
      • 27
      After restarting, error went off, but ground switch of the mains shut off two times while printing. I will try another outlet if there is something wrong with electric installation in the office. Or else, there can be some contact to the housing.
      As I believe if there was electric overload, the fuse (16A 230V) would switch off, but not FID (0.5 A, 230V) (ground switch).
      Thanks,
      Primoz
      • primozks
        • Dec 2008
        • 27
        Found it.
        There was no ground wire it outlet. There were only zero and phase. Ground was bridged with zero wire.
        After connecting to other mains with grounding, everything is fine.
        Thanks,
        Primoz
