View Full Version : km-5050 cassette
dayosoof@yahoo.com
12-11-2011, 05:31 PM
I have a km-5050 I replaced d broken rack cursor in d cassettethat worked fine but later discovered a week later that when u close d cassette,it displays ( READY TO COPY) but immediately displays ( CASSETE NOT INSTALLED) again.....all connectors & cable in d cassette are intact,pls wat do I do next
Sounds like the lift motor, It could have taken out the engine board as well.
blackcat4866
12-11-2011, 06:15 PM
Nothing new to add. Ditto. =^..^=
dayosoof@yahoo.com
12-11-2011, 06:17 PM
Nah,I doubt its d lift motor because I tried a new cassette in & it worked fine,thanks
aodtech
12-17-2011, 06:42 AM
With the cassette removed, push the the switch with the white flange. This tells the machine that the cassette is inserted and activates the lift motor. If a different cassette is working then this tells me that something in the current cassette isn't pushing in that switch. Match it up and check that part of the cassette, shim it if you have to. Also remove the switch and check to see if anything is cracked. All the connector does it tell the machine the paper size, which you can specify manually.
