View Full Version : C350 alternate way to clean led bar
groovy
12-12-2011, 01:55 PM
Hi all,
my cuustomer has a Bizhub C350. Today i went to replace all 4 imaging unit, but there is still a problem:
the customer has lost the led cleaning jig and printouts are blurry in the first 3 cm on top on the page, only with Cyan and Magenta colors (yellow and black is OK)
I cannot insert my hand more for trying to clean the led bars.
There is a way yo clean the led bars without removing the led assy unit? i need to clean it farthest from the front panel.
emujo
12-12-2011, 02:51 PM
Steal one from another MFP just to clean....charge the customer for replacement. I believe the 353 series will work. Emujo
mo0651
12-12-2011, 02:52 PM
Remove the IU's, and transfer belt. Gives you plenty of room.
groovy
12-12-2011, 03:17 PM
Removed IU and transfer belt: stillo no room.
My arm is normal in size, but no way to put in all...
mo0651
12-12-2011, 06:52 PM
Sorry, my arm fits in easily from the end where you pull out the waste toner.
groovy
12-12-2011, 06:59 PM
Ooohhh,
from that end.... tomorrow i will go and try!
EarthKmTech
12-14-2011, 11:04 AM
when these led print heads get a build up and start printing blurry i use my can of trusty electrolube "rubber roller restorer" on a cleaning pad to clean them and it restores you instantly to razor sharp printing. The cleaning device is utterly useless for the kind of buildup that causes blurry printing anyway - unless you moisten it with RRR :p
and before anyone gasps in horror, I've been doing it for years and never had a single issue to date :D
groovy
12-14-2011, 12:01 PM
I followed your hit and now the printouts are OK.
My customer has runned his imaging unit for at least of 150k prints, so it's normal that a little quantity of toner has spilled out from the imaging units.
