View Full Version : Konica 7150
Luther
10-25-2007, 06:05 PM
Anyone have the procedure for turning on the ECM(ELECTRONIC COPY MONITOR) for the konica 7150/7060 , any help would be appreciated
copyguy5
10-25-2007, 07:03 PM
The ECM (Electronic Copy Monitor) is well covered in the Konica 7155/7165 User Guide. This can be found at:
Index of /protectedmembers/111514/Konica7155_7165_Force65manuals/pdf/urg (http://www.copierprofessionals.com/protectedmembers/111514/Konica7155_7165_Force65manuals/pdf/urg/)
Good Luck
COPYGUY5
Luther
10-25-2007, 07:05 PM
thanks copyguy i have the user guide but i need to turn it on in th dip sw mode 1st i think
dbrownlee
10-25-2007, 08:24 PM
Actually, I think you have to turn in on in Key-op mode, not service mode. I'll check in a bit to make sure, but I'm pretty confident in that.
copyguy5
10-25-2007, 09:10 PM
You can download the service manual from:
Index of /protectedmembers/111514/Konica7155_7165_Force65manuals/pdf/sm (http://www.copierprofessionals.com/protectedmembers/111514/Konica7155_7165_Force65manuals/pdf/sm/)
Search the Adobe doc for "25mode", "36mode" etc.
Hope this helps
COPYGUY5
bgbas
10-25-2007, 09:15 PM
Yes it is in the key op mode. The default password should be "00000000" thats eight zeros.
Luther
10-25-2007, 09:43 PM
Thanks guys it's been awhile since i had to turn on that feature
etsmultan
01-16-2009, 08:14 AM
its a good try
