View Full Version : Bizhub C252 touch screen not responding
yormets
12-14-2011, 09:26 PM
This machine has a bad touchscreen. It is totally unresponsive. What happens to these? The rest of the machine works fine. You just can't access anything. :confused: What would be the first thing I should try?
Hansoon
12-14-2011, 09:44 PM
Just a few:
http://www.copytechnet.com/forums/konica-minolta/52415-bizhub-touch-screens-dropping-fast.html
http://www.copytechnet.com/forums/sale-trade-wanted/54630-failing-touch-screens-several-copier-brands.html#post238236
Hans
blackcat4866
12-14-2011, 09:45 PM
Sorry, bad news. These touch screens are expensive. And yes, you'll probably need to replace the touch screen. =^..^=
JustManuals
12-15-2011, 03:51 AM
Just Manuals ~ The Internet's largest selection of manuals ~ Instant Downloads (http://www.justmanuals.com)
Paul@justmanuals.com
Itsthepaper
12-15-2011, 04:09 AM
Try this out, good luck.
PROBABLE CAUSES:
1. Corrupt NVRAM.
Perform the NVRAM Recovery Procedure. If the problem persists, swap a NVRAM from another color MFP (bizhub C250/C252/C352/C353/C451/C550/C650) for testing purposes and see if it corrects the issue. If so, order a new NVRAM (can be downloaded from the Download Selector site under Special Firmware).
IMPORTANT: NVRAM initialize: All data except sales counter data will be initialized.
CAUTION: Never format the CF card on color machines. Write the data to the existing info using the Firmware Imaging Toolkit 2006.
2. A bad connection between PWB-C (p/n 4038 0113 05) and PWB-MFP (p/n 4038 0121 06).
Reseat the Wire Harness Assembly between PWB-C and PWB-MFP.
Note: Machine will appear to have no power because the MFP Control Board is unable to detect when the Sub Power Switch is powered ON.
