View Full Version : banner printing on c5501
primozks
12-15-2011, 09:45 AM
I'm trying to print banner 330x700 mm on c5501, but it only allows one paper in bypass tray. If more than one is loaded, paper jam occurs. Am I missing some setting, which would enable to load multiple papers to bypass tray?
Single paper loading works fine, but... It takes a lot of time to make several prints.
Thanks,
Primoz
twinax
12-22-2011, 08:11 PM
Hi,
You need to validate this fonction.
It is necessary to change the DIP Switch 10-0 = 1 in service mode.
Regards,
Twinax
drodas78
08-28-2012, 07:39 PM
Thanks,
Primoz
Hi, I want to print banner in C5501 with IC-408 fiery. Could you give me detailed explanation to do that?
Thank you.
primozks
08-29-2012, 08:51 AM
Thank you.
In my case all I have to do is define custom paper in print driver as 330 mm x 700 (or more) mm, usually 250 g, finishing face up in bypass tray. But as I remember, the serviceman enabled one option, that the banner can be printed. If it doesn't work with these setting, you have to call service to enable this option.
Primoz
ni311
08-29-2012, 04:21 PM
Take a look on the link below, I believe it is what you need:
http://www.init-digital.ru/upload/files/manuals/Banner6500.pdf
