We have a C252 with about 400k prints on it. The copies/prints are uneven front to back. The side at the rear of the machine is lighter than the front. It does this when copying from the glass and also when printing. If you print out the halftone grids from the test menu, and you lighten the density, the one end almost completely fades away, whereas the front end is still strong. When copying, the same thing. The part to the front of the machine is always darker. We have tried a new belt assy., X-fer roller, and I.U.s. We have cleaned the printheads and tried all the voltage settings. We are stumped. Any suggestions?
Bizhub C252 uneven prints.
Re: Bizhub C252 uneven prints.
Paul@justmanuals.com
We did clean the lasers. After doing more digging, we discovered that when printing the test grid, it only shows on light density. The problem is MUCH more noticable when copying. Checked the positions of the optics. Cleaned mirrors and CCD. No improvement. Anyone else seen this?Comment
We did run the individual colors, in print and copy. When printing, it fades front to back only when set to very light density. When copying, however, the fade front to back is very much more pronounced. Also, to correct an earlier typo, the machine has less than 200,000 prints, not 400,000. We have cleaned everything inside, including print heads, tried new I.U's, new belt unit, and fuser. We cleaned optics. Hasn't anyone seen this problem before?Last edited by Dave10; 12-22-2011, 10:32 PM.Comment
I had similar problem with C220, which got resolved by replacing PH Assy. In your case I tink you have done almost everything. Try swapping right hand side door Assy. OR check for door latches for proper contact of transfer roll with Transfer belt.
Hope this help, best luck.
AjitnComment
Stop it half way, how does the image look on the transfer belt?Color is not 4 times harder... it's 65,000 times harder.They call it "TECH MODE" for a reason. I have manual's and firmware for ya, course... you are going to have to earn it.
Hello everyone,im a young technician and i've encountered the same thing recently.
I did everything you gyus discussed about even stopped the machine while printing a graddation pattern and i noticed
the uneven density starting on the drums(cleaned PH unit).
Has anyone found a permanent solution?I don't like the new copier I just bought. It says "put face down" but every time I do it, it blinds my eyes.Comment
Also another thing that got me confused is that the transfer belt is supposed to be changed at
260k,the machines meter is at 220k and if you look at the parts life the belts life is below half.
The only thing i've changed so far are the drums which are almost brand new.
