View Full Version : HP 4100 reset
frank
05-12-2005, 01:13 AM
how do I reset a maint light on a hp4100, it not the same as a 4000?
raym
05-13-2005, 04:02 PM
press and hold down left side of the \"item\" and \"value+\" buttons while turning printer on. release buttons when \"reset maint. count\" appears in display.
to verify it has been reset, press \"menu\" until \"information menu\" appears. press \"item\" until \"print configuration\" appears, then press \"select\" to print \"config. page\".
good luck,
ray
10871087
05-14-2005, 01:28 AM
there is a list of all the hp pm light reset procedures posted in the download section on this site, gotta keep that one in the truck B)
Sally
06-29-2005, 04:41 PM
I have followed instructions as I understand them but can not get this to work.
Perhaps misunderstanding what buttons are \"item\" and \"value\" placement.
This is HP4100mfp series. Tried top, bottom, left and right to the select
pensivetm
09-09-2008, 06:01 PM
just remove the misformed html tags to read the text:
press and hold down left side of the item and value buttons while turning printer on. Release buttons when reset maint. count appears in display.
to verify it has been reset, press menu until information menu appears. press item until print configuration appears, then press select to print config. page.
pensivetm
09-09-2008, 06:04 PM
How do you get to the downloads section? Is that a pay function?
JustManuals
09-09-2008, 06:59 PM
downloads section?
