View Full Version : Error Code panasonic DP-8060 Error code E03-03
vmchong
12-27-2011, 05:52 PM
Run f8-09 after pm code E03-03 please help!
doug94550
12-27-2011, 07:06 PM
E3-03 is your toner density sensor. Check the harness and how does the face of it look? If it's really worn, you will need to replace it. Try swapping it with another.
Doug
vmchong
12-27-2011, 09:08 PM
Thank you for the prompt replied. I did swap the harness and the sensor but no help. I tested the spcboard cn720 24v ok.
??? no idea.
doug94550
12-28-2011, 02:25 PM
Hmmm...
Could be the harness between the Spc and the dev assy.
Also, take a look at the coupling between the dev assy and the mainframe. I have seen some of them crack.
Doug
