View Full Version : Bizhub error code
Chronus102
10-31-2007, 12:12 PM
i have a C-6102 (i'm pretty sure thats what it was) error code on a minolta bizhub c352, i'm not sure what the code is but i have seen it twice on this machine and just checked the machine for anything and powered it off and then back on and it seems to fix the issue but if it happens again i'd like to know what that code means.
pepper38_cnd
10-31-2007, 01:04 PM
C6102 Drive home sensor malfunction • The scanner home sensor is unable to detect the
scanner located at its home position.
• The scanner home sensor is unable to detect a
scanner even when the scanner motor has been
driven to move the scanner over the maximum travelling distance.
• The scanner home sensor detects the scanner
when the scanner has moved 5 mm from the
position, at which it blocks the scanner Home Sensor.
masterchill
10-31-2007, 06:15 PM
Check and make sure the scanner cables are sitting ok.Slide the scanner and make sure they do not over lap.Had one do this to me.
Chronus102
11-01-2007, 10:08 AM
thanks for the quick input, right now it seems to be working fine but if it happens again i'll be sure to look at what you all suggested, thanks again
cobiray
08-12-2008, 04:23 PM
whoops, should've been a new post
