View Full Version : CLC3200 Dead Hard drive
seanmcinnes
01-08-2012, 04:35 PM
I have a CLC3200 with a dead hard drive, is there anyone who could offer advice on how to get it going again? I have another CLC3220 but reading another post it seems that it is not possible to clone that drive and insert, thought I would ask before starting! I obviously have a new IDE drive ready to install but wondered if there is somewhere you can pickup an iso image for what should be on the disk by default? Thanks in advance.
gensys
01-08-2012, 07:33 PM
Read this >>>http://www.copytechnet.com/forums/canon/49797-canon-ir-5000-hard-disk-clone-help-required.html
See this >>>
http://www.youtube.com/watch?v=CYfjDZ7kOb8&feature=related
SST >>> IS THE WAY TO GO
For best result. Call Canon Regional Service
seanmcinnes
01-08-2012, 09:20 PM
Thanks for the input. I have read this thread - http://www.copytechnet.com/forums/canon/57539-canon-clc-3200-error-code-e000602-0602-a.html which suggests that swapping a drive from a similar machine is a bad idea, so I am really after the Service Support Tool relevant to the CLC3200 so I can hopefully start from a fresh hard drive. Otherwise I am quite familiar with cloning disks so would be happy to do that but am I risking messing something else up? The other machine I have is a CLC3220 which is also slightly different so I am not sure cloning the disk is the best idea? We do not have canon support and the engineer that normally helps me is more of a technical fix it rather than a software fix it!
teckat
01-09-2012, 05:12 AM
iR3220 SUPPORTED HDD's
The Canon OEM # is WM2-5248-000 HDD, WD800BB-22JHC0.
HDWN 'IC35L040AVER07-0
HDWN 'IC35L040AVVA07-0
HDWN 'IC35L060AVER07-0
HDWN 'IC35L080AVVA07-0
HDWN 'QUANTUM FIREBALLP AS40.0
HDWN 'QUANTUM FIREBALLP AS60.0
HDWN 'FUJITSU MPG3409AH E
HDWN 'Maxtor 4D040H2
HDWN 'SAMSUNG SP4002H
HDWN 'MAXTOR 6L040J2
HDWN 'MAXTOR 6L060J3
HDWN 'IC35L060AVV207-0
HDWN 'SAMSUNG SP0411N
HDWN 'HDS722540VLAT20
HDWN 'ST340014A
HDWN 'HDS728040PLAT20
HDWN 'Hitachi HDS721680PLAT80
HDWN 'WDC WD800BB-22JHC0
