View Full Version : KONICA MINOLTA C500
copierlady
01-08-2012, 05:40 PM
I am working on two c500's . The first one has an external fiery hanging off the back of the machine that uses two pig tails to connect it to the machine. I can print to that one.
The second one has a fiery that is built into the back of the machine. I am using window 7 opperating system. I can not seem to connect to that machine. Can anyone tell me what drivers i need to download to connect to that machine? What is different from the other machine that is keeping me from printing?
Networking is not my thing. Thanks.
acusso1234
01-08-2012, 08:36 PM
http://www.copytechnet.com/forums/konica-minolta/60257-konica-minolta-bizhub-pro-c500-w-fiery-ip-921-setup.html
http://onyxftp.mykonicaminolta.com/download/SearchResults.aspx?productid=302
No w7 driver available...try a Vista driver and good luck
copierlady
01-09-2012, 01:14 AM
I installed the driver. I can ping the printer. I can get in with explorer. It will not print. I'm doing something wrong. It must be windows 7.
Any ideas?
sanimir
01-09-2012, 07:07 AM
Try it first with an older system,
This is easiest way to see how and what next.
Also see whether the network cable into the right port.
I knew I had to cheat and plug the cable into the connector of the printer instead of a Fiery.
logrady2331
01-12-2012, 02:23 AM
Could be they both had the external Fiery at one time. Make sure the controller type is set correctly. Don't remember which one it is (1 through 5) but I woud look there.
