PRO C500
  • copierlady
    • 338
    PRO C500
    Working on a biz hub c 500 with saddle stich. Trying to fold 6 pages (11x17) and the machine stops and tells me that i can only fold 3 pages at a time. Is this true. I could have sworn that i have folded more than 3 pages at a time befor, but i may be mistaken. Thanks
  • CKiiza
    • Feb 2010
    • 77
    Re: PRO C500
    I think according to the specs of the unit
    3 sheets is the best you'll be able to get from it unless you specify differently
    TU-109 Trimmer Unit
    Function: Paper feed into Finisher FS-513/FS-606
    Configuration: 2 trays (upper/lower)
    Types of paper: 50 to 256 g/m2 paper
    Paper sizes: Upper tray A4, A4R, B5, B5R, A5, 8.5"x11", 8.5"x11"R,
    5.5"x8.5"
    Lower tray A3, B4, F4, A4, A4R, B5, B5R, A5, 11"x17",
    8.5"x14", 8.5"x11", 8.5"x11"R, 5.5"x8.5", and those
    Wide sizes (max. 314 mm x 445 mm)
    Stack capacity: 200 sheets max. or 30 mm or less (200 g/m2 paper)
    Dimensions: 511 (W) x 620 (D) x 220 (H) mm
    Weight: Approx. 10.5 kg
    Power source: Supply from finisher
    Function: Trimming the end of booklet
    Types of paper: 64 to 105 g/m2 paper
    Paper sizes: A3, B4, A4R, 11"x17", 8.5"x14", 8.5"x11"R
    Number of trimmed
    sheet:
    Fold mode 3 sheets max. (105 g/m2 paper or less)
    Stitch & Fold mode
    20 sheets max. using 80 g/m2 paper
    (19 sheets max. with a thick cover paper)
    16 sheets max. using 105 g/m2 paper
    (15 sheets max. with a thick cover paper)
    Trimming width: 10 mm max.
    Stack capacity: Approx. 512 sheets max. (80 g/m2 paper)
    100 sets max of 2~5-sheet-folded booklet (500 sheets
    max.)
    50 sets max. of 6~10-sheet-folded booklet (500 sheets
    max.)
    32 sets max. of 11~16-sheet-folded booklet (512
    sheets max.)
    Dimensions: 1280 (W) x 610 (D) x 562 (H) mm
    Weight: Approx. 68 kg
    Power source: Supply from outlet
    • copierlady
      • 338
      Re: PRO C500
      Ok, thanks. I must have be useing staples before. Customer needs to mail this booklet and they can't use staples in the mail. Thanks for your help!
