View Full Version : bizhub c252 dim screen
repeatcopiers
01-14-2012, 07:49 PM
I have a bizhub C252 that the screen on the control panel is very dim. It lightens and darkens but still barely visible. I know these touch screens go out often but is this an indication that is about to happen or could something else be the problem? Thanks for any help.
mitchl
01-17-2012, 07:51 PM
Normally the screen has its normal brightness when they go bad but the touch doesnt work, a dim panel is a different problem. If you have another machine available swap the panels, if it has the same problem its either the M board or the C board as I recall. Also try going over the connectors on the boards and make sure everything is seated.
I think it's a PWB-M problem. Try to reflash the machine and see what happens.
sprdav
01-19-2012, 04:23 AM
just had the same problem and it was the main control board, the board on the left side of the copier
