View Full Version : pizhub 350 code c2557
maj143
11-04-2007, 04:50 PM
hi
i have error code on bizhub 350 c 2557
if any one can help me on it
& if any 1 have the manuale [lz send to me on
maj_143@hotmail.com
i have the ricoh & canon manual
Juggy
11-04-2007, 06:44 PM
C2557: ATDC Sensor Failure
If you have replaced developer run F8 in tech mode.
maj143
11-05-2007, 03:50 PM
dear sir i dont change any thing in the copier but if the toner finshed dose it make same code
plz let me know
Juggy
11-06-2007, 05:32 AM
yes if you tried to run the machine for very long time the toner in the dev tank gets exhausted and the developer gets week and you will get this code. Call a technican get them replaced and fix your problem
wagon
11-06-2007, 09:57 AM
After the developer is changed you should change the toner empty stop function to 'ON' to avoid this happening again!
maj143
11-06-2007, 03:30 PM
my dear
im tech but i work in ricoh copier & i want to fix this copier
so if you can help me to do it
do i have to change the Dev & drum or only the dev
or if i do the F8 only
thanks in advance
mitchl
11-06-2007, 09:30 PM
Reset the DV counter............ Had one do this the other day and it wouldnt dump the code till I reset the counter............ Go figure?:confused:
