View Full Version : Di-450 with Pi-5501, W7/64bit driver workaround?
Hansoon
01-21-2012, 03:55 AM
Anybody found a workaround to use a Di-450 equipped with Pi-5501 controller with Windows 7 / 64bit?
Hans
Glaander
01-21-2012, 04:05 AM
Hans
This might work
7 Windows 7 Printer Installation Tips | PCMag.com (http://www.pcmag.com/article2/0,2817,2356158,00.asp)
Hansoon
01-21-2012, 02:14 PM
It seems that there is a PCL5e W7-Vista/64 bit driver "In The Box" Is there a way to extract that driver from a working W7/64 System?
On the KonicaMinolta website there is no download for it.
Hans
Glaander
01-21-2012, 03:36 PM
there is universial driver out there, but is for bizhub, don't know that will work for di line tho.
http://onyxftp.mykonicaminolta.com/download/SearchResults.aspx?productid=1061&filetypeid=17&osid=30
http://kmbs.konicaminolta.us/content/support/universaldrivers.html
Hansoon
01-21-2012, 05:21 PM
Thanks, but they work only for Emperon driven machines.
Hans
Glaander
01-21-2012, 05:44 PM
there is vista driver, I sure that will work if you follow the pcmag.com steps
Support & Drivers Search Results | Product: Di3510 / File Type: Drivers (http://onyxftp.mykonicaminolta.com/download/SearchResults.aspx?productid=328&filetypeid=0)
TheOwl
01-22-2012, 09:50 PM
If there is a 64Bit Vista driver, then use that.
If there isn't, the only way you are going to get any sort of print is to use an HP driver, but you will lose functionality with the finisher and so forth. In the past, this is what I have done for unsupported operating systems just until the client upgrades their machine.
