View Full Version : Error Code Kyocera 2550 Error C3200
Rivered
01-23-2012, 07:00 PM
I Have a Kyocera 2550 that is giving me a C3200 error code. What is happening is, it will not copy and is erroring out on me. I have cleaned the lenses, guide track and removed all smudges from the mirrors. The mirrors are installed properly as far as I can tell. I have gotten it to work by leaving the cover off that surrounds the main optical lense. It will work fine then except it puts lines through the paper, but as soon as I either replace that cover or put the lid down on the scanner, it will error out on me.
Thank you in advance, any and all help would be appreciated.
JustManuals
01-23-2012, 08:38 PM
Just Manuals ~ The Internet's largest selection of manuals ~ Instant Downloads (http://www.justmanuals.com)
Paul@justmanuals.com
Eric1968
01-23-2012, 08:52 PM
Try to adjust and clean the shading plate. Looks like bad shading to me.
aborad
01-24-2012, 10:03 AM
check 6pin flat cable continuity or replace it . also check Scanner home position Switch.
ES-OGT
01-24-2012, 10:33 PM
I've also see the CCD get dirty and cause the same problem. Don't remove it or blow canned air on it but just use your breath and you should be ok.
alexkim
01-25-2012, 04:34 AM
Go to Maintenance mode U61. If lamp is on , Check first inverter PCB, second ,Cable (carefully) and lamp (defect)
if no problem, replace engine PCB.
