View Full Version : CQ C6500/C6501 and the C7000 Drum
ineo+6501
01-31-2012, 04:37 PM
Getting the black spot on drum unit issue that has been discussed on here for a few years now.
Has anyone in the UK/Europe had any success with the suggested use of the DU-104 drum in the C6500/C6501?
There appears to be nothing in the TAD/TNI here in the UK but there has been mention on another thread that KM have released something in other market(s)?
eifling
01-31-2012, 06:22 PM
We tried the 7000 drums in 2 c6500's a couple of monthes ago and have never went back. No more black spots and the drums last on average twice as long as the 6500 drum. Have not noticed any difference in print quality other than they do not wear out as fast as the others as they should not because they are rated for more sheets. Since then all the c6500's in our area have been switched to the c7000 drums and we are now trying the c7000 chargers in 6500's. They also seem to last alot longer but its not as much of a game changer as switching the drums is.
tech51
02-01-2012, 08:39 PM
I agree totally with you, the drums last for a lot longer and the quality certainly holds up. I dont have any 7000 s but use 6501 chargers and 7000 drums in all my 6500`s and have seen no adverse effects at all. It certainly helps with with streamlining car stock holdings!!
Now if only they would make a decent fuser!!!!
ni311
02-08-2012, 12:54 PM
What problems do you have with the fuser on these machines?
dljorg
04-04-2012, 10:48 PM
DU-104 drum is a 100% fix for spotting on black and yellow - experience with 40 machines with the symptom.
ineo+6501
04-05-2012, 08:50 AM
Thanks for the info guys. I have tried the DU-104 in a few problem machines and the spots have not returned.
Cheers
roberto.bertolani
04-20-2012, 09:43 PM
the drum of the 7000 series can be mounted on 6501 and I have no problems with quality and the bottom copy.
are perfect
bye
Mita-Konica-Tech
04-21-2012, 01:42 AM
Just a note don't forget to instal the special firmware on your 6500/6501, if you use the DU-104 Drums; Version GMZ-60
roberto.bertolani
04-21-2012, 08:00 AM
thanks, I verify if there are other news, then you write
ni311
04-21-2012, 10:52 AM
That firmware is useful only if you are replacing the cleaning blade from DU104 to DU102. As already said here and on another topics on this subject, I cannot see why you would replace only the cleaning blade. Experience in field until now shows that DU104 works great on C6500/6501 without any additional firmware. End of story.
roberto.bertolani
04-21-2012, 11:23 AM
I think it's best to change all the dr104 works best and most straight forward, changing the blade is not enough to eliminate the problems of durability and quality copy. Before making a judgment check my FTP for firmware
soon
bye
I nead a part number for DU-104 Drum
ineo+6501
06-22-2012, 08:45 AM
I need a new car
empiru
06-22-2012, 10:13 PM
Yep, I can confirm, the DU-104 works just fine on the C6500/C6501. No spots on them, no error codes, good quality, etc etc
ni311
06-23-2012, 07:34 AM
This thread is 6 month old, I think meantime everyone find the solution.
PS: I won't mind a new car too, can I pick the model?
leo78rom
05-06-2015, 10:37 AM
Hi, how do I install the firmware, where do I get it from?
I just put DU104 on 6500 and I have now an error C-2213
Thank you
gisburn20
05-06-2015, 04:18 PM
Hi
Did you replace the Cyan drum with the DU104? that's a Cyan drum drive error.
Firmware is available on infohub for all qualified engineers, and instructions on how to install it are in the service manual.
Firmware should only be done if you are qualified on this model.
We have been fitting exclusively DU-104 drums to all our remaining 5500/5501/6500/6501 machines for the last few years with very few issues, only a couple of machines needed the new firmware to cure drum drive errors ( the cleaning blade on the DU-104 is more efficient and causes a little more drag)
Try swapping the DU104 from the Cyan to the Black, see if it runs without the error after a restart.
Hope that helps.
tulintron
05-18-2015, 03:29 PM
Here in Brazil, we are using DU-104 in our equipment in 02 years. Greater shelf life and higher quality in some cases.
No problem ...
