View Full Version : Lexmark X642 - 5 beeps problem
savi0r
02-01-2012, 09:56 PM
Hi guys. I'm having this issue with an lexmark x642. The display panel is blank, the led is off and it beeps 5 times, pauses, beeps 5 times again etc. I have checked the cable from the op panel right cover to the scanner board and it seems ok. Before i blame the op panel right cover, is there anything else i should check? Thanks
JustManuals
02-02-2012, 03:09 AM
Just Manuals ~ The Internet's largest selection of manuals ~ Instant Downloads (http://www.justmanuals.com)
Paul@justmanuals.com
mojorolla
02-02-2012, 03:19 AM
5 beeps is an op panel code. Re-seat all the connections on the main board or replace op panel.
Tonerdude
02-28-2012, 08:23 PM
Hate to admit it, but had one doing same thing. Reinserted all connectors with no change. A good swift slap to the left panel took care of the problem. Good luck.
mrizer
02-29-2012, 09:36 PM
Before replacing the operator panel, check the wire that runs to it from the scanner control board. There is a small metal piece on the frame that can rub against it and damage it (see pic below). If that wire is bad, you'll have to replace the upper front cover hing assembly (40X3309 (http://www.iteminconlince.com6/itemdesc.asp?ic=40X3309&eq=&Tp=)). Lexmark didn't spare this cable by itself. The next likely culprit would be the scanner card (40X3305 (http://www.iteminconline.com/itemdesc.asp?ic=40X3305&eq=&Tp=)), then operator panel (40X3301 (http://www.iteminconline.com/itemdesc.asp?ic=40X3301&eq=&Tp=)), then inverter card (40X3304 (http://www.iteminconline.com/itemdesc.asp?ic=40X3304&eq=&Tp=)).
14647
