View Full Version : problem on a c450
jokacross
02-02-2012, 03:09 PM
See the images above. This blue thing dosnt not appear on black and white copy's. need i change the blue IU? what you think? thanks
141811418214183141841418514186
jokacross
02-02-2012, 03:34 PM
one more thing if I put the paper in landscape this not occur only on portrait.
emujo
02-02-2012, 04:52 PM
Hard to believe you need a technical forum to answer this...Emujo
jokacross
02-02-2012, 05:22 PM
yes I know but I really need to know! Some help? Im a donk in this things
minimerlin
02-02-2012, 07:26 PM
Do these "blue lines" appear from every tray using portrait paper? Are the trays centered correctly? :confused:
EarthKmTech
02-02-2012, 07:51 PM
Cyan iu failed.
Make sure to use the print head cleaning tool when you change an IU too, on ALL 4.
You should also do a gradation adjust, but 99.9% of customers give you a blank stare when you say that...
Also remove the carrier thats tracked from this failed iu off the tops of the ones to the right of it before it destroyes the drums in those too.
JustManuals
02-03-2012, 12:49 AM
Just Manuals ~ The Internet's largest selection of manuals ~ Instant Downloads (http://www.justmanuals.com)
Paul@justmanuals.com
jokacross
02-03-2012, 02:08 PM
yes it does in all trays in portrait mode
jokacross
02-03-2012, 02:09 PM
Cyan iu failed.
can you explain me better the last statment? thanks!
RRodgers
02-03-2012, 02:12 PM
It's probably your cyan image unit. Time to get a new one. That is were I would start. And as mentioned me sure to use the cleaning tool to clean the print heads AND the lamps (if the print heads are at 6 o clock the lamps are at 5 o clock)
jokacross
Cyan iu failed.
on more thing theirs no problem using the machine with this iu damage its right? because right now I dont have a new IU that i can replace. Im now waiting for a new one. thanks
jokacross
02-03-2012, 02:17 PM
yes I already clean but nothing happen, now im waiting for a new IU to get this fixed. thanks
qtong
02-17-2012, 06:16 AM
sorry, what is IU?
jokacross
02-17-2012, 10:46 AM
IU Image Unit
