View Full Version : Bizhub 350 Bypass Tray Priority Setting
victorgator
02-08-2012, 11:17 PM
Can anyone please assist me with what setting I need to change in order to force the BizHub 350 to print from the Bypass tray when the tray is loaded? While trying to print a check the 350 prints from Tray 1, even though there is a page loaded in the Bypass tray. In the check printing program, there is no typical Print manager screen that pops up prior to printing.
I'e looked in the Print Operations manual but know I must be looking in the wrong place.
victorgator
02-08-2012, 11:34 PM
Ah, never mind. I figured out a work around. I created a duplicate printer driver called "Bizhub 350 MANUAL TRAY" and set the default tray to Manual Feed.
emujo
02-09-2012, 12:23 AM
Fixed your own issue...I commend you!!!Emujo
Don N.
02-27-2012, 07:07 AM
You nailed it. During a search I found something sort of related...
How to set available paper cassettes for receiving faxes.
Solution:
CAUSE: Not pulling from the proper cassette.
SOLUTION: To select available paper cassettes when receiving faxes, select mode 37 and change bits 2 through 7. Setting the bit to a 1 enables the tray and setting it to a 0 disables it. Below are the default settings:
Bit 7=1 for 1st cassette
Bit 6=1 for 2nd cassette
Bit 5=1 for 3rd cassette
Bit 4=1 for 4th cassette
Bit 2=0 for Bypass
