View Full Version : Konica 7035
stevee104
02-10-2012, 02:57 PM
I have a machine that has shaft assembly that drives the fuser unit that has wore it self down along with the bushing egging out.In the parts book on page 14 the driving unit the shaft is gray out with no part number, can anyone tell me for sure that the part is not made, it goes with gear 31 and gear 22 on parts page 14.
kingarthur
02-10-2012, 03:47 PM
if you have access to the "infohub", lookin the "ocp"....it has 2 part numbers for that part, the old part is 26na15140, which has a "holder" at each end p/no 46607602, the new p/no is 40la15140 which has a "bearing" at each end p/no 26na1728. its under parts modification number KOM090119...
stevee104
02-10-2012, 04:06 PM
No we are not a konica dealer so all i have is a service and parts manual.
The new part number you posted 40la15140 is this the right number i just notice a l after the 0.
thanks
kingarthur
02-10-2012, 04:27 PM
yes it is an "L"...if you have the bushings...then it seems it's the old part number, or else i'd order the bearings as well...just to be on the safe side
stevee104
02-10-2012, 04:58 PM
So i am going to order the new part number 40la15140 , and this does not come with the new bearings so
i will have to order to new ones is this correct. Didn't know if this was a kit or not.
stevee104
02-10-2012, 09:41 PM
Is the part number for the bearing right , my supplier said it was invalided number.
ni311
02-11-2012, 09:17 AM
The code is correct:
40LA15140 - FIXING INPUT SHAFT ~ 2 Euro
stevee104
02-13-2012, 01:50 PM
Can you me a pdf of the bulliten so i can get the part number for the bearings.
CraigW
02-13-2012, 06:19 PM
These are what we stock...they are for the early models (with bushing) before they went to a bearing.
26NA15140 Fixing Input Shaft
466076020 Paper Feed Shaft Holder (bushing)
If it is the type with a bushing you have to stay with a bushing as the bearing would not fit the frame opening.
