View Full Version : solvent cleaners
skynet
02-12-2012, 07:33 PM
What cleaner do you use to remove baked on toner and other dirt? We have used Mr McKenic Contact Cleaner & Lubricant (http://www.mrmckenic.hk/03.html?keepThis=true&TB_iframe=true&height=600&width=900) but are now having problems locating a supplier. This stuff would remove almost anything but eventually ruins plastic parts with too many coats, it turns a clear toner bottle cloudy with one coat ;)
So what do you use?
JR2ALTA
02-12-2012, 07:51 PM
I just carry alcohol, water/soap and a harsh "belt cleaner", I dont know of, or care about any magic bullet cleaner. If the company supplies can't do the job, the part needs to be replaced.
Shadow
02-12-2012, 08:33 PM
Simple Green (http://www.simplegreen.com/)
this is what I have been using for the last 20 years. works great on just about anything. I still use alcohol for charge wires and windex for the glass.
the simple green product works great on feed and registration rollers.
Hansoon
02-12-2012, 08:56 PM
For toner build-ups on non-plastic parts: Acetone
Hans
mx270hb
02-12-2012, 09:09 PM
Acetone for toner
Simple green for rollers
Mr cleans magic eraser for covers
mikadonovan
02-13-2012, 03:27 PM
Mr cleans magic eraser for covers I'm going to try that as the formula "K" stuff I use now is a little hard on the lungs.
Zackuth
02-13-2012, 05:22 PM
We use Martin Yale Rubber Cleaner, which I think is similar to the stuff you are looking for. We also use soap and water, alcohol, and simple green.
charm5496
02-13-2012, 08:18 PM
Kwik Solv and Mean Green to clean the panels.
Rubber Rejuv to clean built up toner and residue from those baked on situations.
If it is really bad we use a chemical called Meter XIII which is an older press cleaner
mx270hb
02-14-2012, 03:59 AM
The trick is to make the section of the sponge your using slightly damp. give it a few seconds to soak in and then rub away.
I am yet to find a mark I can not get off the covers.
Pens and tape residue are simple
boot marks require a bit more elbow grease.
I cut a sponge up into 3 strips.
Hope it works for you!
blaze2000
02-16-2012, 04:50 AM
General clean with 409
windex with a touch of rainx for glass and op panels
alcohol for corona/ grids
small bottle of d-ink for the real nasty stuff
NeoMatrix
02-16-2012, 06:07 AM
I cut up a green scour pad (ones you scrub pots with), into 4 smaller squares, and use alcohol (metho) to clean the built up toner off most problem areas.
DWise
02-16-2012, 08:31 PM
Funds are pretty slim here... so we have had to resort back to the old "cleaning solution": SPIT and elbow grease.
copiman
02-16-2012, 08:54 PM
A friend of mine that owns a pressure washing company told me about this. The name is LA's Totally Awesome. He gave me a container (64oz). the cost was $3.00 at Dollar General. It has a dilution scale listed on it. It list office machines with a 10 part water and 1 part Awesome. I make it a little stronger. I have been using it for 3 months now and I highly recommend it. You can get a smaller container for $1.00 to try. www.lastotallyawesome.com/Cached (http://webcache.googleusercontent.com/search?q=cache:FvEcAGGb3NkJ:www.lastotallyawesome. com/+la's+totally+awesome&cd=1&hl=en&ct=clnk&gl=us) - Similar (http://www.copytechnet.com/search?hl=en&rlz=1T4LENN_en___US448&q=related:www.lastotallyawesome.com/+la's+totally+awesome&tbo=1&sa=X&ei=VWs9T4O0MojWtgeA5PW7BQ&ved=0CEEQHzAA)
There site has store locators.
Jules Winfield
02-16-2012, 10:31 PM
A friend of mine that owns a pressure washing company told me about this. The name is LA's Totally Awesome. He gave me a container (64oz). the cost was $3.00 at Dollar General. It has a dilution scale listed on it. It list office machines with a 10 part water and 1 part Awesome. I make it a little stronger. I have been using it for 3 months now and I highly recommend it. You can get a smaller container for $1.00 to try. www.lastotallyawesome (http://www.<strong>lastotallyawesome</strong>).com/Cached (http://webcache.googleusercontent.com/search?q=cache:FvEcAGGb3NkJ:www.lastotallyawesome. com/+la's+totally+awesome&cd=1&hl=en&ct=clnk&gl=us) - Similar (http://www.copytechnet.com/search?hl=en&rlz=1T4LENN_en___US448&q=related:www.lastotallyawesome.com/+la's+totally+awesome&tbo=1&sa=X&ei=VWs9T4O0MojWtgeA5PW7BQ&ved=0CEEQHzAA)
This stuff is actually really good. My wife discovered this stuff at the dollar store and it works beautifully on all kinds of stuff around the house. I never thought to try it at work, though. Brillianize, Ci7600 fuser oil, and CaiKleen RBR has been working great for the work stuff, so I never though to try La's...
banginbishop
02-16-2012, 11:06 PM
without trying to hijack the thread but what do you use for sharp main charges - the old manuals said polystyrene blocks to clean saw tooth charges:rolleyes:
the new kit thats out there - ive tried all sorts and i end up getting new main charges as its a pita to try and clean.
oh and ive stopped useing solvent cleaners unless im desperate. more prefere glass cleaner, mr mckenic or wd40 based oil products.
blackcat4866
02-17-2012, 12:14 AM
For Sharp primaries I have had success with cleaning the metal housings with glass cleaner.
For the grid, I'll lay down two sheets of clean paper, and lay the grid on top. I'll use a toothbrush and glass cleaner, brushing in the direction of the fine threads of the grid, both sides. I'll dry it with a fine weave towel, wiping in the direction of those fine threads again. If it's not clean I'll repeat until it is, then with a clean dry toothbrush brush away any fuzzies, both sides.
For the sawtooth I'll use a Q-tip with just a little glass cleaner, then brush away any fuzzies with the clean dry toothbrush.
I must confess I don't miss scorotrons much, squinting at the damn thing trying to get every microscopic bit of lint. =^..^=
my 2 cents:
Burned toner with aceton, if it really nasty then Super Kromofag (paint stripper)
For rubber stuff there is Protegum, better than anything I used.
General stuff with window cleaner or tehnical alcohol (90% proof)
Sensitive stuff, like LEDs, with isopropyl alcohol.
devilin
04-18-2012, 04:30 AM
I felt only alcohol worked,
and soap I tried, no matter use,
don't know why.:confused:
