View Full Version : Jamming Konica 7155 without reverse funktion and jam 32-2 or 32-3
Laserbeam
02-15-2012, 09:38 PM
Hi all,
today I had this problem on a 7155. During normal 1 sided copy (with the face down) I always get a jam-code 32-2 or 32-3. The reverse is dysfunctional and the paper runs without stopping through the hole ADU-reverse unit and falls to the bottom of the machine. (See my attachment).
Copy mode with face up in the upper tray works fine.
I replaced the fixing-unit, ADU-board and the ADU-reverse actuator but unfortunately without success.
davidgrifoll
02-16-2012, 05:01 PM
have you the problem with face-up mode???
Laserbeam
02-19-2012, 04:13 PM
no, in the face-up mode all works fine.
davidgrifoll
02-21-2012, 04:46 PM
14517
check that sensors
SmellsHot
02-21-2012, 07:41 PM
in his 2nd picture...your looking for a spring that returns an actuator thru a photo sensor.....make sure it has enough tension, or it will not return in time. Chased my tail on this same thing!!!
Darren King
02-21-2012, 08:03 PM
Also make sure the the sensor is in proper position and actuator isn't broken.
Laserbeam
02-22-2012, 09:54 PM
Okay, I will check these sensors tomorrow!
Laserbeam
02-23-2012, 08:21 PM
@ davidgrifolltoday,
I replaced these sensors (as shown in your attachment) and the respective actuators and now all works fine!!!! :o
Thanks to all for your help!!!
