View Full Version : fax with C450
akbareshghi
02-20-2012, 06:03 AM
i want to connect my phone line to C450 machine ? i read fax manual but can not find any diagram guiding how to connect to phone line for direct transmission faxing
please guide me about fax board and connections of phone line to machine
thanks a lot
Gaffers01
02-20-2012, 10:00 AM
The first thing is to check to make sure it even has a Fax Card on it,
as I know its an expensive OPTION on this model.
If it has a fax on it, you will find it where you put the network cable in.
mrwho
02-20-2012, 10:29 AM
True. If you press the "Fax" button, does anything happen? Near the RJ45 network connector, do you see two (smaller) RJ11 connectors?
