View Full Version : Bh600+FS-604
blago_vd
02-21-2012, 08:50 PM
Hello,
is it possible Bh600 to work properly with FS-604?
If it is, then how?
Thanks in advance.
mo0651
02-21-2012, 11:05 PM
Yes!......Place the bh600. then place a bh920 and plug the finisher in to the 920!
blago_vd
02-22-2012, 07:17 AM
Thanks for the clever answer ...
I'll explain the situation - an customer with working Bh600+FS-604 configuration wanted to upgrade the firmware. I installed V.31 mass production, taken from Infohub. After installing the firmware and restarting the machine, FS-604 can not make connection to the machine.
Any suggestions?
Avskrap
02-22-2012, 12:12 PM
Are you sure the firmware update didn't fail some step? Try reloading it, I've had to do it 3-4 times on some machines, why I don't know... Also make sure the firmware supports the finisher - Some software don't, for some unknown reason.
EDIT: Are you sure it's a FS-604? As the previous clever poster said, it's for the bizhub 920. FS-602 is the folding finisher for the 600, and FS-504/505 are the staple finishers.
mo0651
02-22-2012, 02:23 PM
Exactly!:cool:
blago_vd
02-22-2012, 02:39 PM
Hello,
I've installed the firmware several times, but only first time appeared "fnisher" in ISW board selection menu. After the first installation of the firmware the finisher "disappeared". I know that this finisher is for Bh920, but also this finisher somehow worked with Bh600. The bad thing is that the finisher acts like it has no power.
Avskrap
02-22-2012, 03:03 PM
My guess is that you had a fluke with it working to begin with and now that you've updated the firmware the machine doesn't recognize the finisher. Either downgrade to see if it works or get a proper finisher ;)
