View Full Version : CQ bizhub c203 quality image
granata
02-24-2012, 05:04 PM
Hello guys, I have a problem with the bizhub C203. There 's never happened to a thing, I already replaced IU CYMK, PH and black group with ITB- help
145701456914571
bizhub1
02-25-2012, 12:44 AM
I would try the prcb, had that same issue and the printer control board was the fault.
Nelo
02-25-2012, 06:37 AM
145701456914571
Try cleaning all 4 ph glasses with its cleaner, if its still the same do gradation adjust in the service mode and replace image transfer roller. I suggest you do gradation adjustment before replacing the image transfer roller. If you replaced
PH then check if its positioned properly in to its place.
rprem
02-25-2012, 09:38 AM
hi
It comes in all imaging unit, then it must be a transfer belt issue,cleaning problem,or waste toner is full and also check the second transfer,take printout open the side door while the print is going check the image on the paper and remove the transfer belt and see how is it if the same formation is there then the transfer belt is problem
granata
02-27-2012, 09:35 AM
hello guys, as seen from the photos I have taken apart the IU K, and found an accumulation of developer on mylar of the development group, I put the old IU K and the defect disappeared, and thanks to all
