View Full Version : Miscellaneous bizhub 600 No Incoming Faxes
MFPs R Now PCs
03-01-2012, 01:42 AM
We have the Konica Minolta bizhub 600 in the field that is able to send faxes (only with ECM off) but is not able to receive any faxes at all. We are being told it is connected to Protel’s I.P. T1 flex phone system and an analog port is in place for the bizhub 600. Are there any settings anywhere for enhancing the bizhub 600 fax abilities to work on this type of system?
DUKEY
03-01-2012, 02:00 AM
Make sure you are using a digital phone cord, it has 2 wire contacts instead of the analog 4 contact line, have seen this problem myself, just a suggestion.
RRodgers
03-01-2012, 04:27 AM
New install? Did it ever work and stop working? Did you check the marketing area in service mode?
