Just got a 2nd C6501, and this one is fully loaded, got it with just over 1m total, like 700/300K split. Ran great even with just replacing the Corona's. After running (40K clicks, 10K 12x18 duplex), i started seeing some issues, since the machine was in storage since 2010, i was surprised it go that far. So we do the entire PM, DRUMS and DV and DV units... looked good. But after 2000K or so i started seeing a void on the yellow drum. Pulled the process unit, and found hardened toner on the yellow drum, no way enough coverage to cause voids (light area) that I was getting.
So most jobs are short run, but my own flyers and a few clients i do run higher volume... So i figured if i have to clean some hardened toner every 2000 sheets I could live with it, but its seems to be getting worse.
I cant seem to figure it out. its mainly the yellow drum. but was happening much worse before the PM, replacement Drums, DV and DV UNITS.
I am looking now for mods, or updates that correct this. Drums are the latest "C" revision. I woudl just replace the drum but it was happening before we put over $2000 into it.
using standard ACCCENT DIGITAL SMOOTH 60# 12x18.
After cleaning it gets better, but also seems like there are now some scratches on the drum, but no what's causing the marks....
Any help would be great.
C6501, Booklet maker, RU, FS521, and PF unit w PRO 80 3.0....
