View Full Version : CQ bh C280
acusso1234
03-01-2012, 06:30 PM
Hi all here. I have this C280 whith 450000 prints on it. The issue that you can see opening the PDF is intermittent and black related. I have changed the belt, black drum and developer unit too. I've changed the clutch (A0EDM20000) that allow the rotation of the black developing unit and lasers unit too.. I'm thinking at a memory issue, but Im remaining out of ideas...Do you have some good idea for me?:confused:14653
acusso1234
03-01-2012, 07:48 PM
.....and now the attachment is working. Sorry...
ineo+6501
03-02-2012, 09:04 AM
Is the sample from Print, Copy or both?
What does the black gradation test pattern look like from service mode?
acusso1234
03-02-2012, 10:11 AM
Hi and thanks for your response. It does not matter what kind of job you are doing. The internals tests sometimes are normal and sometimes like the sample. Today I've discovered an arcing between the second trasfer roller assy pin and its contact, cleaned all but again no...
Avskrap
03-02-2012, 11:07 AM
Check the fusing speed and/or loop. I've seen this when a salesman tried helping a customer wanting to print and fold thicker papers without losing quality, which in turn made normal weight papers look like your sample.
acusso1234
03-02-2012, 11:20 AM
Already tried it...here they use only 80 grams paper and no thick is selected, A4 and A3...the problem is still here...
ineo+6501
03-02-2012, 11:48 AM
In that case, I would check for vibration on the black drum drive
blaze2000
03-02-2012, 12:24 PM
I've seen HV1 failures causing this type of pattern. Check your connections or try replacing the board.
acusso1234
03-07-2012, 09:01 PM
In the end i clean the registration roller! The machine had various problems (jams, problems of copy quality and also a deformation of the mylar on convoy transparent of the first cassette and a couple of rusted clutch. 5 Interventions and 15 hours of driving have solved the problem. Thanks to everyone for the help! :)
blackcat4866
03-08-2012, 12:38 AM
Good to know.
I didn't think that it looked like laser or high voltage. The interval is too regular. It almost had to be something mechanical, roller or gear drive.
Thanks for sharing, acusso. =^..^=
