View Full Version : Miscellaneous energy saver C35P
mapel
03-05-2012, 09:39 PM
Does anybody know how to activate the energy saver function on a C35P-version. In the sys default menu i only see saving time. Energy saver has to be disabled.
In our country is probaly forbidden to disable the energy saver function due to energy star label certification.
I guess it goes bij softsw?(these are not communicated in the service manual...)
The printer has the latest Fw.
Michelle W
07-13-2012, 08:07 AM
1. Press the Utility/Counter key.
2.The Utility Mode screen will appear.
3. Touch Meter Count on meter count display.
4. Press the following keys in this order.
Stop →0 →0 →Stop →0 →1
5. Touch Password, and enter the CE password using the display keyboard or the 10-key pad.
Note: The initial setting for CE password is “92729272”.
6. Scroll down to Soft Switch Setting.
7. Change switch 6 to 1 (effective after power is cycled).
8. Press YES then OK.
9. Press the Reset button to return to the main screen.
10. Power machine OFF/ON.
Note: The setting will not be viewable in Admin Settings after setting the Soft Switch. To confirm that the change was made, print before-and-after configuration pages, and you will see that auto shut-off is now set to OFF.
