View Full Version : Konica Minolta bizhub c351 with fiery ic-402 - cable type?
thendral
03-07-2012, 06:04 AM
Hello All,
I have a KM C351 with fiery. When I directly connect the copier byapssing fiery it works fine.
The firey controller has one cable (SCSI type interface connector) but missing other cable (ethernet cable?).
I tried to use the ethernet cable, but the copier is not recognizing the fiery.
I am not sure what type of cable it is. I have a cable crimp I can make one, but not exactly sure what type it is. Is it a crossover cable?
Checked the service manual no use. Any help here is very much appreciated.
Thanks to all.
Thendral
Albonline
03-07-2012, 02:28 PM
yes, crossover. when fiery is connected do you get the info icon on the screen? Are you setting the controler type correctly to use the fiery?
thendral
03-08-2012, 11:04 PM
Thank you Albonline (http://www.copytechnet.com/forums/members/albonline.html) for the reply. I will try with the crossover cable. How can I set up the controller type?
Albonline
03-09-2012, 04:48 PM
download the ic 402 install manual from kmbs
